Broken screen with coloured lines
My daughter has dropped her phone. The screen is smashed with red and green lines. Please can someone tell me if this is able to get fixed if i replace the screen or will it need further attention.
We repair shops see damage like this quite often and she damaged the LCD, which will be replaced when you use a full screen assembly and not a glass only repair. You can order a kit here on ifixit. Just be careful when disconnecting the battery as a lot of DIY-ers and beginners have a tendency to knock off a very tiny component near the battery connector known as battery gas gauge and it’s pretty self explanatory. If it does get knocked off the phone will constantly display 1% battery and reboot every so often. That can also be repaired but you’ll need a specialist. Make sure all the screws go back in the right place. If you put the wrong screw in the wrong place in the phone, you can cause more damage.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 210
