メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
締切られた回答
Where is the cmos battery?
I have a liquid damaged 2007 macbook 2.1 GHZ (A1181) that's working fine but isn't charging the battery.
I swapped out the DC in board and battery connector with known working parts but the issue remains.
I tried an SMC reset several times but to no avail.
I decided to disassemble it to clean up the logic board (there was some corrosion on some areas) but when I took it out and turned it round to remove the cmos battery there wasn't one. I assumed it was removed and not replaced as the macbook had clearly been opened before, but I couldn't find the jack for it.
Here's the type of logic board: http://www.techex.biz/ebaybiz/pics/Mothe...
This is the one I've seen before, where the cmos battery is placed in the middle of the board:
http://67.19.154.220/HQ/apple_macbook_a1...
Where is the cmos battery to be connected on this logic board?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It sounds like you have the Santa Rosa or Penryn version of the MacBook which has a slightly different location than earlier models. Here is the guide showing the location.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Matt! Not calling it the "PRAM Battery" was obviously the downfall of my fruitless searching.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 10,902
