メインコンテンツにスキップ
Repair and disassembly guides for the Alcatel A50 budget smartphone. The Alcatel A50 was released in July 2017 and includes a 5.2-inch display.
21回答 すべてを表示
How much will it cost to fix white lines on a phone screen?
i put my phone in my jean pocket the other day and when i pulled it out there was white lines across my screen so i smacked it and it fixed and its been doing it alot and now it wont go back and i cant enter in my password ( its a pattern password ) how much do you think it will cost to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Zerrik Mitchell  could just be a loose connection on the display connector or a bad display. The display assembly is around USD $30 so if you do it yourself that is what you would be looking at. If you need to get it repaired then it will depend on where you are located etc.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Zerrik Mitchell さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 74
今までの合計 1,528
