メインコンテンツにスキップ
Huawei が製造したスマートフォンの修理ガイドとサポートです。
20回答 すべてを表示
huawei y9 prime blank screen after lcd repair
i recently dropped my Huawei Y9 prime 2019 phone and the screen cracked and I couldn’t use it so I took it in for repairs ,it’s been 3 days now and every time I turn my phone on, press the power button or put in the charger it will light up a black screen but no image appears not even the HUAWEI logo, should I send it back to the repair shop or is the anything I can do to fix it on my on ,I have tried with the restart option of pressing the power button and volume button simultaneously but still no luck
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
Decode the screen Y9 Huawei
さんによる
I have this problem too, how did you resolve it @nthabiseng1
さんによる
コメントを追加
3件の回答
ベストアンサー
Hi @nthabiseng1 ,
You could try shining a torch at an angle close to the screen when the phone is on to check if you can detect any images at all. They will be very faint if they are there, so trying this in a darkened room may help to see them if they are there or not
If you can see images on the screen, then there is a backlight problem but since you have recently had it professionally repaired take it back to where you got it repaired and show them the problem. Most reputable repairers give some sort of guarantee on their workmanship.
Don’t open the phone yourself to try and find out what the problem is and then take it back to the repairer, as this will allow them to say that you caused the problem and that they’re not responsible anymore.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Not sure but this may help you
https://okadtech.com/huawei-y9-black-scr...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
لم يتم شحن الهاتف بالكامل
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
NTHABISENG さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 25
今までの合計 3,583
