メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
iPhone Microphone Issues - works on camera and Siri, but not on calls
Hello,
I have a similar issue to someone else on here, the microphones on my iPhone 8 only appears to work while doing specific things - the microphone works fine with Siri, Front and Rear facing video, but doesn’t work for calls on both speaker and earpiece, pretty sure FaceTime & voice memos records a flat line and plays a cracking sound. I am thinking it is the bottom microphone that isn’t working, and am hoping it is not logic board.
As for history; the screen and back are cracked (bought it like this) particularly near the dock section on the back. However, everything else works fine (as far as I can tell) and I opened the phone up and all water damage indicators are white and the phone is mostly clean with little dust.
Has anyone found a solution yet? I have ordered a new replacement housing with parts so it comes with a new dock connector and mic so I will see if that works!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Microphone is most probably disabled for phone calls. Go to settings to see if this might be the problem, or go to the phone app and check the setting there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Bottom microphone might be broken or not making good contact with the logic board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
TmG さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 58
今までの合計 1,737
