メインコンテンツにスキップ
The PowerBook 100 series kickstarted Apple's line of PowerBooks.
Macintosh PowerBook 145 Screen Issues even after recap
Hi all.
I recently got a PowerBook 145 with startup sound chime, but black/grey screen (only the backlight worked).
So I decided to recap the creen board (I used 9x 3.3uF-63V capacitors instead the 35V original ones) and the inverter board with a 47uF-16V and 33uF-16V (tantalium) caps.
The problem is that, even with this cleaning with alcohol and recap, the display doesn’t work properly… now it turns whit and shows a series of vertical lines, but nothing else.
Is the display definitely broken?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Without having a second PowerBook which you can use to check out the display on all you can do is check the voltages.
My first Mac laptop was a 180c which I used for work, it was much lighter than my Compaq Portable III ;-} I had been using. And the screen was full color! The Amber screen my Compaq had was hard on the eyes!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lumia.nicola さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 393
