メインコンテンツにスキップ
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56回答 すべてを表示
Howdo I narrow down whether its the resistor or the speed control swit
I have power to the motor. And have checked it with voltmeter. Replaced the resistor. No luck there so I checked the speed control switch and it is melted a little on the connector and there isn't any resistance on the switch. I tried jumping the switch but nothing happened there either. So now I want to check the connector on the resistor. However I can't find an help with that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @fordfun ,
Do you mean the blower motor resistor?
Here is an image from the repair manual, showing the circuit for a 2005 F150 auto and manual A/C blower motor and motor resistor.
(click on image to enlarge for better viewing)
Here is the rest of the repair manual in case you need more information.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jeramie Millhouse さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 6
今までの合計 101
