メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1903年に設立されたイギリスの自動車メーカーが製造する自動車の修理ガイドとサポート。
Can get sound through aux/cd but not radio
Hi.got a Vauxhall corsa with inbuilt stereo. Getting sound from the aux cord or CD player but not from the radio.any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Hi,
Something to check.
Looking at a wiring diagram for the 2003 model it shows that there's an aerial amplifier used for the radio.
画像
(click on image)
It may be that the amp has become disconnected from the radio unit, so there's no radio signal being amplified for the radio.
The amp is located under the dash panel near the bonnet release. There should be a small thin wire and a thicker grey wire connected to it. If the small wire isn't connected then you won't get an amplified signal
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have a 2014 Vauxhall Corsa, the CD player works fine, but the FM/AM tuner has no sound, I can scan for stations & save radio stations, but when I switch to the tuner, there is no sound?,
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I don’t know if you managed to sort your problem out but if not then here’s a few things to look out for.
If your stereo is DAB then try an FM or an AM channel & see if you get any static sound from the speakers. ie not tuned in correctly. If you don’t, then go through all of the audio settings on the stereo & make sure it is not in ‘MUTE’ or the Auto Volume is not set too low.
Also check the Balance & Fader settings. Try adjusting the Fader to the front speakers only & see if that makes any difference. If not then try the rear speakers via the fader. It maybe someone has wired the speakers up incorrectly via the Fader settings. Sometimes the radio works separately to an AUX input or CD player.
Because you said you get sound from the CD & the Aux input, i would say 100% it was something to do with the radio’s audio settings.
Hope this helps.
Gazza
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have this problem too, anyone got a solution. ?
さんによる
コメントを追加
回答を追加する
ady.starmer さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 29
過去 30 日: 102
今までの合計 7,483
