Home button is not working
I can’t tell if the home button cable is broken or not and if it is how could I fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
hello Ryan,
depending on the fault, sometimes HB flex is possible for fix. If you haven’t experience, find a good repair shop.
In the meantime, you can us “assistive touch” function (settings—>about—>availability—>assistive Touch—> switch on). It’s kind of emulation of your home button built in IOS. Unfortunately, you will temporarily lose touch ID functionality.
このアンサーは役に立ちましたか?
Thank you so much
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 66
