Leaking water from bottom whether is on and off
Black and Decker house iron , leaking water from bottom whether is on or off when up right positions when not using ( maybe crack internally/water tank/water system)?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @charlieccc ,
What is the model number of the iron?
You may have to dis-assemble it to see where the leak is and whether or not it can be easily repaired. For example it may be a faulty gasket rather than a split in the tank
このアンサーは役に立ちましたか?
Thank you Jayeff!
Sometimes you cannot get a gasket. High temp RTV could be very helpful.
how to repair it.please upload video.
過去 24時間: 5
過去 7 日: 17
過去 30 日: 56
今までの合計 1,719
