メインコンテンツにスキップ
任天堂の最初の3DSモデルは日本で2014年10月に発売され、北米では2015年9月に発売されました。Newニンテンドー3DSは改良された3D機能、Cスティックと新ZLボタン、ZRボタンが特長です。
84回答 すべてを表示
My new 3DS volume is no longer working
I own a New Nintendo 3DS, never dropped it, never got it wet, always kept it in its case but I just stopped using it for a while. I decided to use it again and found that even if I move the slider, the volume stays super low. I’ve taken it apart properly to check if it was a slider issue but it isn’t. Is there anyway to fix it or is there a piece I can buy to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@rsharky check the speaker ribbon cables and connector. You could try to connect a new speaker assembly (or for now just another speaker rigged to it) and see if that makes a difference. Also, check the audio jack and see if that works better/at all. If none of that works there is always a possibility that this is caused by a bad audio IC. Let us know what you find out with a new speaker first.
https://www.ifixit.com/Store/Game-Consol...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
@oldturkey03 I checked the ribbon and connectors there was nothing wrong with it. I don't have additional speakers with me. However, I noticed that even when I connect headphones in, the volume is still low. Also would that speaker assembly work for a regular new 3ds, not the XL?
さんによる
@rsharky "that even when I connect headphones in, the volume is still low" makes me think that there is something else going on. Let me see if I can get some more info on the audio IC.
さんによる
コメントを追加
回答を追加する
Rachel M さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 36
今までの合計 887
