メインコンテンツにスキップ
2011年7月21日に発売されたMac Mini Mid 2011モデルはCore i5もしくはCore i7プロセッサ、Thunderboltを搭載しています。
204回答 すべてを表示
Second hard drive cable included on all models of 2011 mini?
I understand that the Server model is only available in a 2 drive configuration. Therefore it must have both cables. Also, the base model $599 version is only available from Apple as a single drive. Therefore it is definitely Not included.
So, the question is, will a $799 mini that is configured from Apple in a single-drive configuration include the second cable as well, or not?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
No, unfortunately Apple has decided not to include the proprietary second hard drive cables in their non-server models. Luckily, we include them in our dual hard drive kits along with everything else you need to install a second hard drive in your Mini.
Hope this helps!
Mac mini Dual Drive Kitの画像
製品
$26.99
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Thanks for the info! I figured this would be the case.
さんによる
When do you expect the kit to be back in stock?!
さんによる
Yeah it would be great to know when the kit is expected to be available again. Otherwise I need to purchase all the pieces elsewhere which is a pain. Thanks
さんによる
Jake, just to be absolutely sure I'm understanding: is your double drive kit compatibile with the entry-level mini? The one only sold with a single drive?
Also, is the kit available in Europe? Or, can it be purchased directly from you?
Thank you very much,
Paolo
さんによる
コメントを追加
回答を追加する
armandotechgeek さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 7,582
