How to remove the heat sink from the motherboard?
Not sure how far you are into this, but to remove the heat sink you will see 4 screws around the end of it and 2 screws farther back towards the fan. Those screws will need to be removed. The will also need to be removed as there is a screw under it also that hold it in place.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 11
過去 30 日: 11
今までの合計 169
