メインコンテンツにスキップ
Repair and disassembly guides for electronic keyboards.
214回答 すべてを表示
Keyboard only works after unplugging it for about an hour
I have a YAMAHA P45B, digital piano. Up until recently, my keyboard has been acting up.
When I try to turn it on, the red power LED flickers non-stop and is completely unresponsive.
However, I leave it with the power adapter plugged out, after about an hour, its working again.
But when I turn it off and on after, the issue returns, LED flicker no sound.
I'm only able to turn it on normally if I leave it with the power adapter plugged out for about an hour.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
First name  sounds like something overheating on the power board. We really would need to see the boards. So, disassemble it and post some good pictures of your boards with your QUESTION. That way we can try to narrow it down. To work on your Keyboard, download the SM from here Page 60 and on will help you to check your boards.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I ran the test program from the service manual, everything seems to have passed, and ran the test on the test points, all values seem to be fine. Also uploaded pictures of the circuit boards
さんによる
コメントを追加
回答を追加する
First name さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 4
今までの合計 90
