メインコンテンツにスキップ
PlayStation Vita, PCH-2000 シリーズの第二世代モデルです。PS Vita SlimもしくはPS Vita 2000として呼称されています。2013年秋に日本国内で発売され、2014年5月に米国で販売が開始されました。
74回答 すべてを表示
Small tab came off during reassembly
The small brown tab that clamps the ribbon cable for the back case onto the motherboard just popped off while I was putting the cable back in. Attached are pictures of the tab,
the ribbon cable on the back case,
and the pins it fits into
(the white slot) does this go back on and if so how? I have large fingers and can barely see what I’m doing. Does the cable work without it being clamped down/can I just tape the cable in the slot? The disasembly guide on here could really use an overhaul, it just says to reverse the steps, but getting things back together is much different than taking it apart. That and it skipped steps relating to the ribbon cables.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
eric jiga not it will not work without it. Well, not properly anyway. That little tab holds down the cable to make proper connection with all the contacts in that connector. You’ll find if you do not use it, the display will most likely not work. That tab is really hard to see but some of those have little bumps on the ends that insert into the connector. You’d need to post a macro picture of this to see it :-) .
Worst case scenario would be having to replace the connector. It is possible but requires some pretty good skills and tools to solder it on.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Is it possible to push the pins down manually without the tab? And do you think the tab can be re-attached since I still have it? Thank you for the help.
さんによる
try to reattach it but be careful. They do not bend easy and love to break. No, there will be no pressure to close the contacts on the connector with the latch. I know it does not seem like much but it will really no close the circuit. Sometimes it works for a bit just to fail again
さんによる
コメントを追加
回答を追加する
eric jiga さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 25
今までの合計 739
