メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
How can you recover data from a completely dead iPhone 4?
I have an iPhone 4 (or 4s don’t remember) that I used to use back when I was a teenager years ago.
I have lots of messages and photos that I’d love to see again, but I’m pretty sure the phone was water damaged. It’s never turned on either when plugged into a pc or charger.
Phone is completely lifeless.
Is there a way to recover all its data? Like, can I buy a working iPhone 4 and swap its motherboard or something?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
You mentioned that it may be water damaged, therefore to confirm this you should follow an ifixit guide to open up the rear cover and check the water stickers (red means water has got in, white means it is fine however these stickers are hyper sensitive and get red even with a bit of water vapour), if you have any tools to check the electrical flow on the motherboard after putting in a charger it would help, and later you may need to desolder the flash storage chip. Unfortunately these are simply my knowledge and I am not certified to do this kind of soldering work, so i am only able to help you up to here. I wish you good luck in getting your memories back.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The storage is unfortunately on the motherboard, so replacing it would just give you the data of the iPhone that board came from.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Recovering the data required making the phone usable again, replacing a few individual chips that controlled functions like USB, touchscreen, and the display.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Truzzie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 81
