メインコンテンツにスキップ
The Italian manufacturer Saeco manufactures manual, super-automatic and capsule espresso machines. Newer appliances can also feature the Philips or Gaggia brands.
247回答 すべてを表示
Why does my Saeco Classico blows house fuse?
My Saeco Classico espresso maker was working fine and suddenly developed a problem, namely as soon as it is switched on, it breaks the circuit in my house. I have opened it up, and all the wires and connections look clean and intact, I can stop the problem by disconnecting the wire going to the heating element. Not sure how to further diagnose or what to replace.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
C. Ronald Kahn this “disconnecting the wire going to the heating element “ could be the part that shortens the circuit. I suggest that you check the resistance across the heating element (I’d expect a resistance between 5 and 25 Ohms). Let us know what you find. Also, post some good pictures of your Saeco parts etc. with your QUESTION so we can see what you see.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
C. Ronald Kahn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 145
