メインコンテンツにスキップ
The Sony α6500 can be identified by model ILCE-6500. It's a mirrorless, digital E-mount camera with APS-C Sensor. The Sony α6500 was released in November of 2016.
11回答 すべてを表示
replacing or tighten screen on hotshoe mount
can you tighten or replace the multi interface shoe mount that’s on top of the Sony a6500?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Sometimes, the screws holding the mount may become loose over time. You can tighten these screws with a small screwdriver (like a precision screwdriver). There are usually small screws located at the base of the shoe mount.
さんによる
Replacing the shoe mount requires removing the old one and installing a new one. The process typically involves removing screws on the camera body and carefully detaching the old mount. Once the old mount is removed, the new one can be secured using the same screws. This might require some technical skill, and it's best to have it done by a professional repair service if you're not comfortable doing it yourself.
さんによる
コメントを追加
3件の回答
Yes, you need to push the little tabs on the sides up if when you put a flash or accessory on it’s lose.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
im asking how to tighten the screws that are on top of the camera for the flash. The screws are lose and need to be tighten i just cant figure out how to tighten them as the sides are in the way.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Could you post a picture
さんによる
just google top of a6500. Its not the flash but the hot show mount for external flashes. Mine has came loose due to the screws falling out.
さんによる
コメントを追加
Theron did you ever sort this issue? Have the same problem and can't seem to get the 2 little screws out under the first cover of the hot shoe on my a6500
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Theron Buchanan Jr. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 648
