メインコンテンツにスキップ
AppleのPad 6のWi-Fiのみのモデルは2018年3月に発売されました。32GBと128GBの容量オプションがあります。9.7インチRetina ディスプレイと64ビットA10 fusionチップを搭載しています。
150回答 すべてを表示
LCD showing multiple of the same image after rebuild
I was fixing a broken screen/digitizer on a 6th gen iPad and now have issues with the LCD after rebuilding it. Your guide was great. Minus dealing with the broken glass, I had no major issues disassembling the iPad and the reassembly was easy. Things went wrong though when I turned the iPad back on to check to see if the new screen worked. The LCD was now showing multiple of the same image. There’s also a white bar near the top of the screen. I’ve attached a photo so you can see what I’m talking about. I was super careful with the LCD when I removed it and don’t recall bending it or putting any other significant force on it… however, I’m not ruling out that maybe I did. Is my LCD hosed or is there something else I can try to fix it? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Take it apart and inspect the display connectors and cables for damage. By the looks of it you did leave a few fingerprints on the LCD but that’s not a huge issue as you can gently wipe them off. Anyways if the connectors look good I would try another LCD. If a new LCD still shows the same problem them you’ve probably got a board issue on your hands and it will need to be repaired by a microsoldering specialist. Did you make sure to disconnect the battery and put something under the board between the battery before disconnecting the screen?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Connectors and cables look good. I did disconnect the battery as shown in the guide. I will try a new LCD and see if that works. Thanks.
さんによる
コメントを追加
回答を追加する
Ryan Glaske さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 40
