メインコンテンツにスキップ
2012年11月2日に発売された第四世代のiPadです。16、32、64GBモデルがあります。モデル番号はA1458です。
212回答 すべてを表示
I pad will not turn on
I have an iPad that ran out of battery one day and hasn’t been able to charge ever since that day I pulled it out of my drawer of junk after it being in storage for four years and crossed my fingers but nothing. I’ve cleaned the lighting port connecter and have used the power adapter for my MacBook and nothing I’ve also tried to hard reset 10 times and nothing and left it charged for 2 days and nothing .Their is a very faint clicking noise when I connect the lightning cable. Any advice on what I can do to fix this issue?
PS sorry about the grammar.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Sounds like a dead battery. You can replace it yourself by following this guide.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
I tested the amperage and it says .005and the volts said 5 is that too low
さんによる
Do you mean with a USB Ammeter? If so, what that is telling you is that no charge is taking place. Considering the age of the device and the time spent in a drawer, you almost certainly have a bad battery. That is the first thing to try.
さんによる
I ordered a new battery and lighting port I will change them and let you know what happens thanks for replying.
さんによる
Hello i ordered a new battery and replaced the battery works now but im getting an error that says
[Nand] _FindFlashMediAndKeepout: 601 physical nand block ofset 1
[nand]_fetchBorrowedList881 number of borrowed blocks 16
さんによる
Hello again so i replaced the battery and the ipad turned on but it gave a NAND error 601 and said blocks borrowed 16 at the end of it also the amps that were drawn were 1.1 and then after a day that number went down to .01 is their anything else i should try?
さんによる
1以上のコメントを表示
コメントを追加
Possibly display LCD has broken down. You can try to change the screen or and battery. I guess battery need to change or re-charge by a Technician.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I tried connecting it to my computer and nothing. should i try downloading itunes or should my computer be able to read it without itunes.
さんによる
コメントを追加
回答を追加する
Assem Nagi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 59
