メインコンテンツにスキップ
Screen Flickers after login
So suddenly one day it started acting weird... It booted up, brought me to the logon, I signed in, and then the screen started flickering color and black. The weird thing is, I never saw the dock at the bottom (all I saw was blue and black) but it happens after I sign on. I just shut it down, and restarted, and now the screen doesn't even turn on. Is this the inverter cable or the logic board (I think it was stepped on)
Thanks!
Edit: The screen doesn't work at all now that it's unplugged and using battery. I can randomly get it to work plugged in.
Edit 2: I left it on for a while, and it went into standby mode and the backlight turned on. I tried to wake it from that, but then the backlight turned off. What the heck.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
To help isolate the problem plug it in to an external monitor. See if moving the screen changes anything. Hold a flashlight at an angle to the scree and see if you can discern the desktop. Let us know your results. Thanks
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I don't have a min-vga monitor or adapter (I can get one if needed) But I shined a light and I don't see anything. Sometimes I can actually see the login screen and logon successfully (backlight and all) but then it starts flickering...
さんによる
Defective CCFL backlight may have the following symptoms: Screen flashes on red/pink and goes off. Picture stays on in red and slowly be come normal. Picture flickering with dim display. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of its life.
Here's my previous post on this with links on repairing the CCFLs: CCFL Backlight Repair and Information...
さんによる
I'm not so sure that its that... It seems to work just fine until logged on, then I get a blue and black flashing, and it eventually dies. I'm not sure if I see the desktop, it just looks like some form of solid blue.
さんによる
コメントを追加
回答を追加する
Mason Curry さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 685
