メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
Installing a blank internal hard drive
Hey guys! The internal hard drive of my Xbox One broke completely into the point that it is unreadable by the Xbox and my PC. It was a simple hard drive failure, with the hard drive ‘reading hand’ somehow lagging, which caused the magnetic structure of the hard drive to lose all data. This means I cannot transfer any data from the old drive to a theoretical new drive.
Can I simply buy a blank new hard drive, punch it in the Xbox One and turn it on? Or somehow use a flash drive to install a new OS on the hard drive? Is there any way I can make my Xbox One work again?
Thanks in advance :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You can’t expect it to work like the PS4, Xbox One is not designed with internal HDD user self-service in mind.
Although it is possible. There are utilities exist to format blank hard drives exact like Xbox One factory default, then download the correct version of the OS image and manually put all the files there, then the console should be ready for a recovery boot and you can further recover it to actual factory default.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Cool, thanks for the answer! Can you name a utility I can use to format the hard drive? And where can I download a correct version of the OS?
さんによる
Something like this:
https://www.pcsavants.com/tech-tips/xbox...
Not sure if it is still relevant or up to date, but you can try.
さんによる
コメントを追加
回答を追加する
Harri Huttunen さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 66
今までの合計 2,313
