メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
625回答 すべてを表示
iPhone battery not showing after replacement, plus one more
After replacing my battery, it was working fine for weeks. But suddenly, my phone started rebooting with the battery percent not showing and the battery indicator being red and low at the beginning of the restart. After that, my phone works fine. Once i opened it back up and re-seated the battery cables the battery percentage never came back and the phone acts like it’s nearly dead, despite the near 100% charge on the phone. Any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
選択されたソリューション
There are some tiny components next to the battery connector that allow the battery to communicate with the CPU about charge level. When these are accidentally dislodged during a repair, it will cause these exact symptoms.
I would open up the phone and closely inspect this area because they may have been partially damaged or dislodged during the repair and only came fully disconnected recently following a drop, for example.
Check the components highlighted in red in the picture below.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
From what i'm able to see with my bare eye, i dont see anything where R3201 should be. Is there supposed to be something there? And if so are there ways i can get it replaced or fixed?
さんによる
It should definitely be there. Bare eyes may not suffice, especially if you're no longer 25 years old ;-). Use a magnifying lens or jeweller's loupe (or your camera zoom) to see if it is there or not.
さんによる
コメントを追加
I am having the same issue with 5 times magnifier i dont see any components that are missing. any other possible issues
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ray McDonald さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 48
今までの合計 1,179
