メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
679回答 すべてを表示
iPhone 8 plus not charging, but wireless charging after housing swap
Hi, i did a housing swap for my iPhone 8 plus, and everything seems fine, but i can’t get it to charge with the charger wired, wirelessly it charges fine but when i plug it in it doesn’t charge. when the phone is ran out of battery and i plug it in the battery icon shows its charging, and if the phones off with battery and i plug it in, the apple logo shows but i can’t get it to show as charging without wireless charging when its actually on. can anyone help? thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
So what most likely is your issue, is that you damaged the charge port its self, it can be replaced but thats what your issue is to my knowledge. another way you can check too see if that is the issue check the microphone and see if that works and if the loud speakers work, if neither of them work as well with the charging then you need to get a charging port replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Was that backhousing a new one with preinstalled dockconnector? Otherwise take out your old dockconnector and try that one,
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
ive tried different dock connectors and still the same issue!
さんによる
take a look at your logic board especially around the battery connector maybe a small component was knock of?
さんによる
コメントを追加
回答を追加する
lewis さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 12
今までの合計 261
