Focus of nikon 55-200 lens stuck
My Nikon 55-200 mm f/4-5.6G AF-S lens focus is stuck midway. I can't use the lens and camera is displaying can't use non cpu lens . What may be the reason for this ?
The "can't use non cpu lens" error means the lens is not communicating with the camera. Assuming other AF-S lenses work correctly, check the contacts on the lens and camera and confirm they are clean and that the contacts on the lens are springy and all look similar. Contacts are rarely a problem on their own though. More likely, there is a problem in the lens, perhaps a cracked flex cable.
--- sam
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 217
