How can I fix the dent on the aluminum without replacing the display?
I had recently dropped this Mac from half feet above the ground onto concrete and there’s this minor dent that happened just on the front, close left to the area where we open the lid. To make matters even worse I used a nail trimmer and rubbed on it to make the thing even, but it created a hole and I can see it every time I close the laptop. It’s little annoying. Found no solution on the Internet as to what I could do. Mostly they tell me to replace the body when taken to Apple store. It’s costly as the panel has the display attached to it. Is there a way I can just apply some thing to close or fill the dent?
Help appreciated.
4 件のコメント
are you able to provide a picture of the damage? iFixitでの質問に画像を追加する方法
Zach Mentz さんによる
@zmentz I just posted the image to the original question. I also had done some rubbing to the dent to make things even, but it created a hole.
Vijay Kanta さんによる
Ok interesting. So you can try and use "epoxy putty" ive used it before on my old HP laptop, but as of now that seems like the best solution to try, but ill keep looking into it and update any further research if that doesnt work
Zach Mentz さんによる
I was advised to use a Silicone Sealant as opposed to a epoxy putty as it's currently not available at my place. Do you think it can get the job done?
Vijay Kanta さんによる
