メインコンテンツにスキップ
Why does my Laptop stuck in running circle?
So It all started today after I finished my online classes and well My laptop just stuck and wont start. I tried turning it on and off and pressed all the button and stuff but still it won't work and this is the only thing that shows up
. Help I really want to fix this as soon as possible because of my online class. Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Maybe hard drive died.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Try the following:
Turn on the laptop and when it boots into Windows, force turn it off by holding the Power button until it completely shuts down.
Do this 3 times in a row i.e start > boot > turn off > start > boot > turn off >start > boot etc.
On the 3rd attempt it should boot into the Windows Recovery Environment menus.
When in the menus select Troubleshooting > Startup Settings > Advanced > Startup repair and follow the prompts.
If that doesn’t work try Troubleshooting > Startup Settings > Advanced > System Restore or System Image Recovery (if you have a restore point set or system image that is).
Do not select Reset this PC. If you choose a wrong option after this you may lose all your data as Windows will be reinstalled.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Silver Acetate さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 362
