Icemaker wont produce ice
If there is no flow of water to the ice maker what is the failing component that caused this?
If the water inlet valve is defective, or if it has insufficient pressure, it won't allow water to flow through. As a result, the ice maker won't make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 77
1件のコメント
@yarddawg what is the exact model number for your fridge?
oldturkey03 さんによる
