メインコンテンツにスキップ
In 2002, the third-generation model was introduced which saw the model move further up-market. Planned and developed under BMW ownership the third generation was to share components and systems with the BMW 7 Series.
3回答 すべてを表示
No audio system available? No radio tv I pod no audio system at all?
Hi my Range Rover sport 2012 autobio has no audio available see pics for info. Iv changed the battery recently due to it been sat flat for a while.
also I have tried changing the amp and still nothing. Iv tried disconnecting battery terminals and leaving as reconnecting. The only idea I have left is a software update so I’m hoping someone has an idea. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hey Aaron, was it all working before the battery going flat?
On the infotainment screen, does it show the volume level'?
If the amp has been replaced then it may need programming to the vehicle which will include it being updated to the latest software level.
Have you been able to get anyone to read the fault codes?
If you have access to wiring diagrams I would suggest checking the powers and grounds to the amp before moving forward.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aaron Perks さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 33
今までの合計 254
