メインコンテンツにスキップ
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
88回答 すべてを表示
Why is my Jeep “Misfiring”? Every morning when I pull out of apt lot?
For some reason like clockwork, every morning when I take my fiancé to work. I start my Jeep, let it run for a bit to smoke a cigarette, then once I pull out of my parking lot, and then turn onto the busy street. It’s always busy so I have to step on the gas to make that left turn to avoid getting into an accident but even on days when there are no cars around, and when I step on the gas It feels like it’s having a hard time trying to get up to 20-40 mph, and then with my foot on the gas, it feels like the Jeep is misfiring or going into neutral. Like I step on the gas then once I feel that it’s having a hard time or misfiring, I would take my foot off the pedal then it will slow down, and I would put my foot back on the gas, then it finally catches up , and I’ll be able to drive my Jeep normally again with no issues. For some reason this only happens every morning when I’m taking my fiancé to work and rarely any other time throughout the rest of the day. Would anybody know what’s wrong and what I would have to do to fix this issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
kristianmolo what engine size does it have? Sounds like a cold start issue since it resolves later during the day. Not sure where you are located but places like Autozone will scan your OBD and hopefully that would shed some light on this.
さんによる
コメントを追加
1 件の回答
As the comment mentioned above, it also sounds like a cold start issue to me. Is it throwing any warning lights like check engine or transmission? You should be able to take it to an autoparts store that has an OBD scanner if it’s throwing codes. If not take it to a reputable mechanic they should be able to get down to the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kristianmolo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 49
