メインコンテンツにスキップ
Released September 2016. Identified by Model No. SM-G610
168回答 すべてを表示
j7 prime is not recognized by PC when connected but charger works.
My pc does not recognize my j7 prime, l tried different usb cables, computers, l got the same results. could it be that the usb port on j7 is faulty ? by the way, the charger works just fine using different usb cables.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@kevin49 if your setting on your phone and your computer have not changed it should be recognized. IF it does not then I would suspect this to be an error of the port. Yes, it may still charge since that is all part of a different circuit. Disassemble your phone and take a look at the connector. You can uses a multi-meter to measure for continuity from the cable to where the connector connects to the board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Adam Ward さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 33
今までの合計 912
