Why my pc automatically entering bios mode, when turning it on
My pc entering bios setup when turning it on
If your computer keeps booting to BIOS, the issue may be triggered by the incorrect boot order. Just go to check if there is an appropriate boot device available in BIOS. If you find it, set the disk as the primary boot option. If your hard drive listed under boot device cannot be found in BIOS, change this hard disk.
このアンサーは役に立ちましたか?
A problem with the keyboard will cause this problem.
このアンサーは役に立ちましたか?
Bios or system batt flat needs replacing
It can be wrong BIOS setting just try to load DEFAULT SETTING and you will see. Or if you start up to BIOS do you have correct time and date ? It can be cache battery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 2,310
