メインコンテンツにスキップ
The Smart Oven® with Element IQ® is a trustworthy tool for the cook who wants a countertop oven that roasts succulent meat, broils, bake pizza, reheas leftovers and toasts evenly. Convection setting reduces cooking time by up to 30%. Model: BOV800XL
29回答 すべてを表示
Power but no heat - thermal fuse seems to be ok
Our toaster oven turns on and lights up but does not get hot. After some research I thought it might be the thermal fuse but after taking the dang thing apart the fuse seems to be fine when tested with a multi meter. So maybe it’s the heating elements but those are expensive and tough to get to. Before investing time and money anybody have any ideas about how to test if it is the heating elements? I mean, would they all go out at the same time? Other thoughts about problem.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Raphael Gutierrez verify your toasters make and model. Since you checked everything else already you could always check the heating elements.....
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I had the same problem. Upon examining the power circuit board there was a loose connection on one of the big elements, I think it was a relay of some kind. I added some solder and it's been working fine again for the last three months.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hey team toaster oven!! I have a problem with my start button…. It’s not working as much any more. It does work, kinda. Any ideas on how to fix this? Please? My best friend calls it the “magic oven”.
さんによる
コメントを追加
回答を追加する
Raphael Gutierrez さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 24
過去 30 日: 101
今までの合計 2,112
