メインコンテンツにスキップ
The Samsung UN55KS9000F 55-inch 4K SUHD TV is a flat panel 2160P TV. Released from Samsung in 2016. Model number: UN55KS9000FXZA.
27回答 すべてを表示
UN55JS9000FXZA with blue screen and sound
When I turned TV on, it displayed blue screen, I connected dvd with one connect box, I have sound. When one connect box is disconnected, sometimes I see half-displayed message showing to reconnect one connect box with different multicolor vertical line flickering over the message. Then the whole screen fade to blue. sometime it displayed the blue outright and stay bluish, when connect dvd to it, you could notice change of dark blue to light blure as the movie is playing. Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Hi @effortenergy ,
Can you view the menu screens OK?
さんによる
@jayeff Im not 100% sure if the tv ports are bad or if the peripheral's video cables are bad
さんによる
Thanks for the response. What are the tv ports and videos cable. I noticed the t con is extremely hot. When turned off the tv for couple of days. The tv would start up, displaying samsung when it got to hdmi and app screen it would then fade out to blue. I'm open to an to help for now
さんによる
@jayeff not at all.. just plain blue screen
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi @effortenergy,
It seems like it is a mainboard problem more than a tcon board problem.
It is more likely the mainboard as it that controls the signal output to the screen via the tcon
If it were a tcon board problem you would have no video at all every time or vertical lines from the start rather than the logo being OK every time? with no problems then vertical lines and after that a blue screen. Also usually a solid blue screen indicates no signal received on a lot of TVs and the logo works because that image is provided by the eeprom on the mainboard.
Best I can suggest is that you order a replacement mainboard from a supplier that accepts returns for a minimal restocking fee to reduce the cost to you if it is not the problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This sounds like a peripheral problem, meaning, a DVD player or whatever there is hooked up to it, has a video issue, or i guess it could be the connection ports on the TV itself, try replacing the video cables then respond
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I connected dvd to the one connect, I could hear the sound but no picture. I used the dvd on different tv, and it worked.
さんによる
I only got sound and no picture when connected to dvd . I used the dvd on other tv and it worked fine...
さんによる
コメントを追加
回答を追加する
Luke Kehinde さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 8
今までの合計 999
