メインコンテンツにスキップ
冷凍庫を含む冷蔵庫の修理と解体ガイド。
1699回答 すべてを表示
The temp display has changed significantly
@ladytech I have the same issue. I have noticed that after unplugging and plugging back in, the temp display has changed significantly. Like before unplugging it says -5 freezer 55 fridge and then after unplug/replug it will say -1 freezer 59 fridge. Too short a time for temp to change that much.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
@joshbrasel I have the exact same problem. Did you ever resolve the issue?
さんによる
@joshbrasel Dang. I have already replaced the fan but that didn't do the trick.
さんによる
@ssluter do you notice any frost forming anywhere in the freezer or fresh food section?
さんによる
@ladytech No. See photos from the last time it happened: https://imgur.com/a/inXCYN5
The first time it happened, the top of the evaporator had frost. Now every time we notice the temp going up, we pull the plug for a minute then plug back in. Seems to fix it every time.
さんによる
@ladytech One more clue - the fridge is fine unless we turn on the icemaker. Not a coincidence, every single time we turn on the icemaker the fridge temp goes up. I haven't tried to turn it on in over a week, and we haven't had any issues.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
@ssluter if the sensor located on the evaporator coil was incased in ice, it should be replace. It could give a false temp reading to the board. Unplugging will reset the board.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
ssluter さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 28
