Sometimes laptop shuts down immediately after starting to boot
Hi, I have HP Zbook 15 laptop (kinda old, bought in 2014). It has a factory configuration plus additional SSD on the M2 slot, which I use for my OS.
Recently it developed a strange bug. Occasionally, when I turn it on after either a full shut down or a hibernation, it would start boot up sequence, but shutdown after only a second, not even loading the BIOS. As a result, no error log is generated to check what might be the problem. And after that, if you wait a few seconds and boot up again - it starts normally as nothing happened… Usually just waiting a few sec is enough, although a few times I had to wait more for some reason.
I first thought it could be battery, but I had it occur without battery too. It has happened both after I left the laptop plugged in and after I disconnected it and took it with me elsewhere. Also, as it is kinda hard to reproduce, so it is difficult to analyse. Any idea as to what might cause this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
