メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
20回答 すべてを表示
How to remove screw with stripped screw head?
There’s a 1.3mm T3 that I can’t get out. I read the info on putting solder into the head, but I’m not sure I’ve got the skill to carefully do that.
I’ve tried a rubber band, super glue, and using larger sizes. I think I’ve now got a nice round hole in the screw head.
Any other ideas to try? I’d made it half way through the battery replacement guide when I hit this!
Thanks.
Les
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Finally found a solution. It’s a little less aggressive than using the Dremel, but the same principle.
I went to Home Depot and got a set of precision screwdrivers which contained a 5/64” flat head, and a set of precision files, containing a “3-way” file.
I poked a hole in a piece of paper to fit over the screw and taped it down with some painter’s tape. I then took the file and slowly started to file a groove into the screw head. It took a bit longer than a Dremel would have, but I felt more comfortable using something where I had better control of the cutting speed.
I’m not sure if there was enough to grip if I’d bought the pliers for a go. If they would have worked on the 1.3mm T3, the description of the pliers should contain that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Consider getting what's called an “easy out" kit for small screws.
These work very well.
Damaged Screw Extractor Kit and Stripped Screw Extractor Set. Its A HassleFree Broken Bolt Extractor and Screw Remover Set Made From H.S.S 4341 With Hardness 63-65hrc. https://www.amazon.com/dp/B07GZ17QD9/ref...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for responding. I looked at that, but the screw is smaller than what the kit is meant for. Also, to use that I'd need to have a replacement screw, and I don't know where to get that.
さんによる
コメントを追加
回答を追加する
Les Hartzman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 2,328
