メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
710回答 すべてを表示
iMac Shuts Off When Seating Display Back into Frame
The power supply went bad in the Imac so I replaced it. The computer will boot with no problem now until I set the display back into its proper location. Even having it tilted out 2 inches it will work until I set it all the way back and then it shuts off. When everything is connected to the display all 4 led’s light up on the logic board and the screen works. Even with the screen completely disconnected from the motherboard it will shut off as I place it back into the frame!? I can disconnect the display completely and run the computer off of an external monitor. I’ve checked for loose cables and cannot reproduce this until I put the screen back in. Very strange situation! Any help is greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The display might be pinching some cables, or unplugging them slightly. It also could be shorting out in bare metal somewhere.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 43
