No response when pressing gas pedal
changed throttle and pedal sensors…still no change ?!?! Why???
Hey @jefffknt. You may need to go through the fuse box and see if there is a fuse blown to module that controllers your pedal sensor. I would just take my time with a multimeter reader on the continuity (is when you touch the red and black together and the multimeter makes a buzzing sound) to check EVERY fuses one at a time. Ford is good for having multiple thing on one fuse.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 13
過去 30 日: 28
今までの合計 686
