How do you replace the transmission belt?
The transmission belt is worn and I need to replace the belt. Do I have to remove any parts to replace the belt?
Other than the spark plug wire and the spark plug, I would say no. I would remove that spark plug just as a precaution against any possibility of the engine firing while replacing the belt. I would think you could replace the belt by merely rotating the crankshaft in the run direction and derailing the worn belt downward off the typically larger transmission sheave. Install new belt in similar fashion.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 582
