Where can I get replacement hinges for HP Pavilion 15-cs0051cl?
Where can I get replacement hinges for HP Pavilion 15-cs0051cl??????? I love this laptop, but the hinge on the left is broken and the one on the right isn’t far behind!
If you are looking for just the hinges these appear to be HP Spare Part Number L23884-001. You should be able to order these directly from HP if they have them in stock or you could do a search on Ebay to see if you can find them there as well. It might also be worth picking up a spare set of screws (L23915-001) in case you’re missing some. That could be another reason the hinges are not as tight as they should be.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 14
過去 30 日: 21
今までの合計 448
