メインコンテンツにスキップ
Slim, lightweight and stylish, the Swift 3 is the ideal laptop for working on the move. The latest NVIDIA® GPU, Intel® CPU and long battery life are housed inside a choice of displays: an elegantly silver chassis with a 13.5” 3:2 ratio 2256x1504 IPS VertiView Display or the vivid colors of a 14” 16:9 FHD IPS display.
Acer swift sf314-54 screen removal
Hi all, I have an Acer swift sf314-54 which the screen needs replacing , however it dose not seem to be held in with screws to the back case like models before and ater it, I havent been able to find a ‘how to’ to remove it either, so dose someone have any advice on this please.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
The best advice I can pass along is to search for a service manual. This should have disassembly instructions.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This model's LCD screen is attached to the cover with Double-sided tape, you will need a hair dryer to heat up the edge then use LCD pry tool to slowly peel off the tape.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
colin さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 25
今までの合計 1,968
