メインコンテンツにスキップ
9月20日に発売された、Appleのメインストリームとなる2019年iPhoneモデルには、6.1インチLCDタッチスクリーン、デュアルカメラが搭載されており、6色から選べるカラーセレクションです。iPhone XRの継続モデル。
476回答 すべてを表示
Did I break face ID?
Customer came in with an iphone 11 screen that was cracked topside and in restore mode. There was a lot of dirt/dust/etc on 1 of the selfie cameras and dot projector. I replaced the screen and updated the iOS and the phone worked. I tested face ID but it wouldn’t let me set it up. It says that I have to try again later or that my face is out of view and I need to reposition it. Portrait mode says I need to move further away. Proximity sensor and auto brightness works when I tested calling someone. I called the customer and asked if face ID worked and she said yes what I don’t really believe. If I am correct the dot projector is broken, but I did not remove the selfie cam.
Is it possible that unlocking works but setting up a new face ID fails or if it’s broken, nothing will work.
I have replaced a lot of iPhones with faceID and have never broken one before. Is this the first time?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Can you post pictures of the device and potentially damaged components? I have a policy in my store for situations like this. I perform a functionality test before any repairs are attempted. If I can’t test everything, I’m not liable for those components because although the customer claims those parts were working when it came in, I don’t 100% know that and unfortunately you can’t take everyone’s word for it. Sounds like you should have a similar policy in place. If it says to move around, you may just need to adjust the front selfie camera assembly a little bit and make sure the sensors are seated properly as well. And why was it in restore mode?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The parts all look fine, but it is an insurance claim so we are adding the face ID to the list. Thanks for the suggestions
さんによる
コメントを追加
回答を追加する
KWH さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 150
