メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
Bottom left of screen turned grey/black after the screen replacement
I bought a cheaper iphone8 plus with shattered screen . I was hoping to fix the screen and start using it. I replaced the broken screen with the new one. When I turned on the phone, the bottom left of the screen turned greyish/black. I thought that it must have been the circuit problem. I uninstalled the screen and reinstalled it but it still the same. Old screen didn’t have that issue. What could be the problem. Please help. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Do you still have the old screen at hands? connect the old cracked one again and see if that has the same problem. If the old one works fine you simply got a bad display from your supplier, unless you damaged it during the repair.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No I do not unfortunately. I threw it away. I don’t think that the display has gone wrong. I installed another Logic board in the phone using the same display and it works fine. Could it be the motherboard?
さんによる
コメントを追加
回答を追加する
shanparshan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 94
