メインコンテンツにスキップ
Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
143回答 すべてを表示
Not sure what’s up with computer?
So I just built a pc specs are
GTX Asus ROG 1070 ti (used)
ryzen 5 2600 (new)
Asus rog b550-f MOB (new)
16GB Corsair ram 2x8gb (new)
corsair tx750w psu (used)
so finished building it had windows up and running, played some war zones on max testing it worked great, went ahead ran benchmark tool got good FPS and temps were below 70 which is good so went to bed, next morning power it on reset my ssd to clear junk and start files fresh and did few downloads hoped onto final fantasy 15 demo see how it’ll run with that cause why tf not and as I’m &&^&^$ with the settings screen goes black look at the GPU and instead of my beautiful rainbow rgbs it’s orange and the fans are at 100% use then it shut off, let it sit for a bit cause well figured I !#^&@@ it off with the orange lights and fan speed buttttt when I turned it back on yea everything boots on all fans power up and all that but the GPU is blinking red, on my board the yellow boot light on the Qled is on hard drives are running he’ll put them back in my laptop to make sure yea they work so tried resetting the cmos didn’t do $@$* took the little battery out put it back nothing !&&* tried the cmos and battery together that didn’t even work so let it sit for few hours try all that again still monitor say no connection from the pc tried plugging the display port in the MOB and GPU took the GPU out and tried just the MOB disassembled the entire pc put it back together tested all my ram slots 1 slot at a time yea nothing still soooooo anyone know what else to do except hit it with the screw driver till it works. Oohhhh also I cleaned the absolute &&^& out of all the parts like even took the GPU apart
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Try connecting a system speaker to the motherboard and check if the motherboard is passing POST (Power On Self Test) on power up. (Not quite sure with your question as to whether it is or not). See p.1-19 of the user manual for the location of where to connect the speaker. On p.2-17 you’ll find the beep error codes for the motherboard.
If there is a hardware component failure beep error code on startup there may be a problem with the motherboard.
If there is a no vga beep error code it may be the GPU card
Your CPU doesn’t have integrated graphics so if the motherboard passes POST then there is a problem with the GPU card.
Also the CPU doesn’t appear on the Asus CPU support list for the motherboard. That doesn’t mean that it won’t work, just that maybe it hasn’t been added to the list, although usually they start with the lowest spec one first.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Thomas May さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 140
