メインコンテンツにスキップ
The third iteration of the 10.1 inch Galaxy Tab tablet.
125回答 すべてを表示
Can't figure out what's wrong with my Tab3 10.1
Hello guys.
First of all, i want to apologize for my bad English . I am portuguese, but I prefer to describe my problem in English in order to have better chances of help.
So, i got a Samsung Tab3 10.1 and suddenly it start to show some charging issues. Last week, i stopped being able to charge the tablet. I thought that was the battery dying, so i changed it for a new one. My problem still not solved with a new battery. When i connect the tab trough USB port, to my laptop, the computer beeps like something was connected, but still no image appears on the tab. So, my question is, what can i do to detect the real issue? Is it motherboard? Screen lcd? Charging flex?
I will be very grateful if someone can help me.
Hoping some feedback.
Thank you all!
Mário Eusébio
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If computer is not reading the tablet as a usb-device or you can’t see in your tablet transfer options, there is a chance that you have a bad charging port, or some pins are not making full contact with the board. You can try with a new charging port/charging port flex, and if it does not work will be a charging IC problem.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Charging IC problem, means a new board right?
But, even with a new battery, it shows no signal on the tablet screen. Can it be multiple issues?
さんによる
コメントを追加
回答を追加する
Mário Eusébio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 107
