メインコンテンツにスキップ
2015年3月に発表され、同年4月に発売されたGalaxy S6はGalaxyラインの中で最高のデバイスです。端にカーブが施されたスクリーンはGalaxy S6 Edgeです。
486回答 すべてを表示
Samsung S6 won’t turn on only showing (white led)
I’ve tried most key combos. I’m going to take this explanation from DroidGuy because it matches my exact problem. “I have a Samsung Galaxy S6. I had it hooked up to the charger all night, woke up the next morning, saw that the battery icon was full and green. When I went to turn it on, the whole screen went black and I have not been able to get it running again since. I tried all the troubleshooting there is, still nothing. The only thing that happened is a solid white LED light.“ The phone has a lot of sentimental value to me and it’s not an option to take to the store help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
you fix this? i have the same problem
さんによる
I’ve just found my old Galaxy again which has this exact problem. Still no way to fix this?
さんによる
コメントを追加
5件の回答
最も参考になった回答
I have this problem on the s6 edge+. phone boots up and after a minute it freezes and then shuts down or restarts with the white led on. Cannot use it for more than a minute unless i constantly engage the digitiser(by drawing a 0 on the screen or in a pencil erasing motion). So i’m guessing this issue could be a display shorting or something related to the display connector.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
try using another charger or if that doesnt work do a master reset usually when u gimet the white light its a sign battery is dead
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi... I have the same issue ... but in desperation I banged it a little then it worked for few hours and now it’s back to the white solid light ... I tried the same trick again and it is just stuck at the Samsung boot up screen. Frustrated ... wonder if someone can help please as I also have a lot of memories saved up in that phone and I don’t want to completely erase it until I have the memories backed up. Any help please ?
さんによる
コメントを追加
After you turn on the phone, you don't need to do anything. After a period of time, the device may be able to boot normally. This is one method I have tried.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It happened to me now and it happened previously. Just wait for the charging to end and then it will open
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
sorry what do you mean, charge it fully then it will turn on? thanks
さんによる
コメントを追加
This problem is related to a hardware issue.
Could range anything from NAND/UFS failure or issues with the RAM or anything.
Samsung hasn't documented anything on this.
I'm still working out what it could mean.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Fix S6 さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 47
過去 30 日: 230
今までの合計 7,914
