Battery not charging or holding a charge.
this iphone will not hold a charge i can plug it up to the wall and it works perfectly but as soon as i unplug it goes off.
Definitely a battery problem! Change the battery, or better yet, see if it is covered by a warranty and let the company you bought it from replace the whole phone.
このアンサーは役に立ちましたか?
Just replaced battery from here last night, worked fine. Put it on charger last night, as I normally do and it was dead when I woke up. It has the battery picture on the screen, but says it is charging, but won't turn on at all. Did I mess something up or is it a battery problem once again?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,951
2 件のコメント
Is there water damage? the connector for the battery might be corroded and need to be reflowed.
iRepairMan さんによる
New battery?? Just a guess...
iRepairMan さんによる
