メインコンテンツにスキップ
Model番号 A1225 / Mid 2007とEarly 2008 / 2.4, 2.8もしくは3.06 GHz Core 2 Duoプロセッサ
433回答 すべてを表示
Diagnostic LEDs OK but no power
My customer's iMac is not booting at all. When the power button is depressed, the optical drive makes a sound as it resets the optical part, diagnostic LEDs 1, 2 and 3 light up (the LCD is currently disconnected), and nothing else happens. The hard drive does not spin up, no fans start, nothing. I've tried starting it in Firewire target mode but that doesn't work. I tried resetting the PRAM and the SMC, but no results. The customer took it to the Apple store and they determined that the logic board and power supply must be OK, probably based on the 3 diagnostic LED's and said it was most likely the LCD. I don't buy that. Even with the LCD disconnected, I think it should be booting. Am I wrong about this? When searching the Interwebs, I can't find any pinout voltages for the power supply so I don't know what to test for there. Any ideas based on your experience?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hook up an external monitor to help isolate the problem and let us know your results.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
powerbrixx さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,177
