Backlight works, no picture, Replaced TCON. XBR65X900E
I bought a TV 2nd hand, has an issue where the backlight works, and you can see it “highlighting” different portions of the screen, but no picture.
I replaced the TCON board with two different boards and same result. The service manual says that you can unplug the LVDS cables from the TCON to enter display “test mode” which will display test patterns. These do not come up either.
Is the panel bad at this point? Possibly the mainboard? If it’s the mainboard, it’s a rather expensive repair.
EDIT: No Flashing Light. Just a solid white light
Did you ever end up figuring out the issue? Just came across this same issue with my 65x900e.
Anthony Fiorino さんによる
Never found a solution. Ended up throwing out the panel.
I swapped the motherboard, and no difference.
rockysnow9 さんによる
had my tv diagnosed yesterday same issues and model as yours. said was the panel and cant fix so its garbage only 4yrs old. guess sony doesnt make panel replacements and is why its not fixable.
jason b さんによる
